OK, just installed this last week, now I need some info on some of the settings (default settings), oh, just so you know, the stove is brand new from HD.
Manufactured date = 5/12
Serial number = 110790
I've posted the above info with the hopes that someone in Tech Support for this stove comes back with some info / answers.
Right, best start with the config (setup).
Corner instal, 7" from the wall left rear side, 6.5" from the wall right rear side.
Flue adapter
45 bend
2' (2 x 1') horizontal pipes straight out the wall through the wall thimble (updated this info)
Clean out T
2 x 3' vertical straight pipes.
1' pipe (this takes me 1' above window outside.
90 bend
End Cap.
Right, now that I've got the details of the install out of the way, I now need to know.....
1/ What are the default values of the 3 lower buttons ?
2/ Do these (LFF / LBA) also have an affect on heat ranges 3 - 9 ?
3/ Why is it that when I increase the room air blower speed, the flames in the fire box also increase / become more intence ?
4/ The stoves Air Room Blower shuts down sometimes, but just before it does this, it makes a lot of noise like it's catching on something and then just grinds to a halt. It only comes back to life if I turn the stove down to heat range 1 or 2. Why ? And why the loud noise at speed 4 - 5 setting ?
Total area that I am trying to heat is about 750 sqf (living area), I can not seem to get the temp above 70 deg C and thats with it on 9 - 9 setting. I also know about the other settings (A,B,C,D), setting C runs my hopper dry in 9 hours !
Would be great if I could get some feedback / help with this.
P.S -- Factory Reset = 5-4-1 and A mode and 1 - 1 for the heat and blower settings !
Flue adapter
45 bend
Clean out T
90 bend
End Cap.
