I'm a new owner of this wonderful mechanical/electronic marvel, first season and about 20 bags into the Canadian winter. So far, only a few minor issues, mostly answered by reading here. In fact, I read every thread from a search on 'Englander 25-PDVC'.
Now, my topic: The manual that came with my unit includes 1 page on what to do/expect in the event of a power failure (p.11). From that, I gather that if the unit is without power for <3 minutes, and it was 'on' when the power was cut, it will automatically go into the start-up cycle with the auto-ignitor when the power is restored. If >3 minutes, it will be 'off' when power is restored, and a manual pushing of the 'on' button to initiate the start-up cycle will be required.
I bought a small gas generator (rated for a continuous 800W, peak of 1000W) to power the stove for just such an emergency. I determined that the stove has a consumption rating of about 3 amps @ 110V, or 330W. The generator is rated at 400W output at 50% load, and should run for about 6 hours at that demand on a full tank of gas. Seems sized right for the purpose, and I got it on sale for $100.00.
My concern is that the auto-ignitor will be turned on whenever the power is restored and the start-up cycle is initiated, either automatically or manually, and I don't know if the generator will be able to handle the current draw.
Does anyone have the electrical specifications for the auto-ignitor?
I'm assuming it will be on for the duration of the start-up cycle, which is about 13 minutes, and I'm worried that it will either be damaged from inadequate amperage/current from the generator, or it will damage the generator. Should I consider putting a toggle switch somewhere in the circuitry to allow disabling the auto-ignitor, so I can start the fire manually?
