Hey I recently purchased a used englander 25-PDVC pellet stove mfd 2014. That a friend used to heat his cabin and now it’s in my 500 square foot garage and I’m having no luck getting it to heat the space.
The stove will lite by itself, burns good but you have to be inch’s from the front to feel the blower putting off lukewarm air. The blower works. I even took it off and cleaned the blades as well as blow out the dust in the stove with an air compressor. When I put this stove on 3-3 in 12 hours it burns about 30lbs of pellets and my garage will only be 6 degrees in the morning. Almost like al the heats going out the exhaust. I took The large plate out and cleaned behind it and put it back in tight against the back of the fire place.
I had my lower settings at 5-4-1 and changed them to 6-4-1 with no improvement. I’m using the same pellets that heated the cabin no problem. And the chimney only runs a short distance out the back wall. the ash is fine in the burn pot when I clean it and the glass isn’t getting super black. Between bags.
When I’m working in the garage I can set it to 9-9 and maybe get 12 degrees Celsius around the unit but the other side of the garage is still cold.
The garage is insulated, and with my little ice fishing heater I can get the temp to 17 degrees.
