Hi all,
It's been a while since I've posted here, but I have a problem this evening. It is supposed to get around 20 below zero tonight, so I tried to fire up my pellet stove when I got home. Upon startup, everything went fine, as it did when I started it a few days ago.
Pellets ignited, as they should, then a min or 2 later my breaker was tripped and I was now getting a room full of smoke as I have an out, then up vent system. I would expect this to happen, but maybe not so much smoke if my vent system ran up then out instead.
Anyhow, I went downstairs to reset my breaker, then fired the stove back up. Pellets instantly re-ignited and stove was in start up mode, but not yet hot enough for the room fan to kick on. Then after about another min or 2 and it tripped the breaker again. Back downstairs I went to the breaker box.
Well, yes I fired it up again, and in about a min or so it was hot enough for the room fan to kick in. Stove was still in start up mode.
Of course, after a couple min it blew the breaker again. I then proceeded to unplug everything I could find that may be on the same circuit and of course fired her up again.
Once again, after a min or 2 breaker was tripped again.
Back to the basement I went to visit the breaker panel once again and say hello to the spiders yet one more time. By now I was getting a bit of a work out, going up and down the stairs, ( my fitbit must be proud of me) and my house looked like something you might see in a Cheech and Chong movie, although the smoke didn't smell as you expect from those guys. I must also say that after getting a bit heated myself from doing the stairs in my fairly round body, the 25 below zero wind chill actually was refreshing as I stood in the doorway to air out the house.
At this point I sat down to think about things for a minute, and decided that seeing as the pellets were still smoldering away in the burn pot and laughing at me, that I would disconnect the ignitor wires, so the stove wasn't drawing as much power to it.
Well, here I go
I pressed the on button again to give a whirl yet one more time.
As I sat and watched the clock pass by the 2 minute mark, I was thinking maybe I'll get lucky this time because it was usually after only a min or 2 had passed that the breaker would trip. Lo and behold, I shortly passed the 5 minute mark, and shortly there after my stove kicked out of start up mode and into regular running mode.
It is now running as it should
! yeah![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
My questions here are the obvious.
Time for a new ignitor?
Could it be something else?
Am I ok using a gel or small torch to start the pellets until I get the situation fixed?
Has this happened to you?
I'll now say thanks in advance to anyone out there that may give me some help, this forum rocks when you have questions to ask and the people here are usually pretty helpful. Who knows, this post may even help someone in the future if they are going through the same thing.
Stay warm, gonna be a cold one around here for sure. ( speaking of cold ones, I could use one of those too )
Well, here I go
