Hello...
I have a Englander 25-pdv stove that doesn't seem to be putting out much heat in the past few days. I clean the stove regularly
https://www.hearth.com/talk/threads/50215/
We burned our way into a second pallet of pellets and I suspect the new brand may be part of the issue. The brand is Michigan wood pellet fuel {from l0w3s} My real question is...are there any of the factory settings that I can change to help with the burn rate? Also what should the factory settings be by default? There is a possibility that my daughter decided to help *adjust* the furnace settings. {read push buttons and see what lights up *sigh*} Any insights would be appreciated. Thanks
Current Settings - Low Fuel Feed 5
Low Burn Air 4
Air on Temp 2
Low Burn Air 4
Air on Temp 2
