Hello folks,
I wasn't able to locate the answer to my question in the forum so my apologies if this is a repeat topic.
I just recently purchased an Englander 25-PDV pellet stove that I plan to install within the lower level family of my raised ranch house. This lower level room is about 3 ft subterranean with the remaining section of the room being above ground. In such an instance, would I be able to use Englanders outside air kit to supply my stove with fresh air or should I use the 3 inch diameter pipe to supply the fresh air? My assumption is the latter but I haven't been able to find any reducers that connect 3 inch pipe to the 1.5 inch air inlet pipe on the back of the stove...
Has anyone else installed this model of stove in a basement and used the 3 inch diameter pipe to supply their stove with fresh air? If so, would you be willing to share insight, part numbers or images that will help me with this installation?
Thank you in advance for any insight that can be provided
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
