I have a Englander 25-PDVC pellet stove. My problem started initially with a E-2 code. I found out later on after pulling both augers and cleaning the tubes that I have a cracked vacuum hose. I replaced the vacuum hose and reassembled the augers. I kept getting a back burn and had the smell of smoke. I did replace the door gasket as I had black glass. THe glass now stays clear, so I’m assuming no air leak there. If I have a bad gasket on the augers bearings, could that air leak cause a back burn through the bottom auger? Also i removed the burn pot to make sure the igniter was properly aligned with the hole. Does that gasket between the burn pot and the main unit need replacing too? Sorry for having so many issues. In summary I now have two augers with new bearings that freely turn and pivot, lubed. Vacuum hose replaced and clamped on both ends. New door seal and now glass stays clean. I fired up the stove, had a great fire for 15 min then checked again with the fire appearing to be burning inside the bottom auger as you look from the front glass. Help![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
