the stove has been installed in an uninsulated basement, which will soon be done.
i had been told the stove was pushing cold air and not heating at all. i went to her home, started the stove,and the heat was ok at 5 feed 5 blower speed.bumped it up to 8-8 and didnt feel much change,after checking it several times over a couple hr span.
i checked the bottom 3 buttons and got 1=4=1 for settings. i tried to change them a bit, but when i pushed the first button and got the 1 reading and then the up arrow the number didnt change...same for the other 2.
the stove is in maine, so i am assuming the factory presets are goining to be a bit different than a preset for virginia. is the board defective if i cant change the settings, or am i doing something wrong?
any help would be appreciated, until i get a chance to call tech support or talk to mike holton.
thanx,
mike btw, the oak is hooked up.
thanx,
