I recently installed a englander 25-paf pellet furnace. I have a question as to weather i can turn up the blower fan higher than the temp setting. the manual says they should match, but i dont seem to get enough air flow from my vents through out the house. i have it ducted into my plenum of my house furnace (which is turn off). the heat output seems good but i have very weak air from the vents in all the rooms. the first nite using it it went through almost 2 bags of pennington pellets on a setting of 5 and 5. is this correct?
also the fire went out after about 15 hours running, there was a large clump of pellets,looked like a dry piece of sea sponge. i cleaned all the holes in the wear plate and the side holes in the burn pot hoping this would help.So today i found a air leak at the glass seal, i replaced the gasket and fired it up, the flame looked hotter so i have it set on 4 now with the fan on 5, think this will be ok? any advise would be helpful. thanks.
