Englander 25 EPI
I was curious as to whether the 25 EPI has a variable speed combustion blower motor or is it constant speed. I know the convection blower is variable speed.
Variable. If you increase the air on the Low Burn Air button, the comb. blower has to be able to change speed.
I think he meant just going from one heat level to the next? Not LBA
Yes, I figured that, but I used the fact that the change in the RPM of the combustion blower when changing the LBA indicates a variable speed motor. I'm pretty sure it changes with heat settings too.
