This forum has always been a great source of info so I'm hoping someone can shed some light on a problem I am having. I purchased a re-manufactured 25 EP in Oct this year and have been burning daily since then. I usually burn at 1-1 or 2-2 but with the cold stretch lately I went up to 3-3. As soon as I put the blower up to 3 it runs fine and then all of a sudden everything bumps up to what seems to be a 9. The blower is really going and it appears that the feed rate jumps also. This goes on for about 5 - 10 min and then cuts back down. Pushing blower speed buttons has no effect on this at all. When I first got the stove it did this for the first day no matter what setting I used and then it stopped doing it and ran normal since. I figured it was just getting settled in but as I said, now with it up to 3 it is happening again. There doesn't appear to be any pattern to it, everything is fine and then the bump up and on it's own it goes back to normal.
Sorry for such a long post but maybe someone out there had a similar issue and can give me a some advice. Thanks for any help or thoughts anyone has. BTW - just for info - I am burning Barefoots, OAK installed, corner install out the wall to a clean out T and up 3-4 ft and I follow the daily clean routine. Thanks again
