I have an englander 13nc with back and side shields. What is the minumun length of a 24ga metal wall sheild spaced 1' from the the wall...to be placed behind the stove?
JPapiPE said:I have an englander 13nc with back and side shields. What is the minumun length of a 24ga metal wall sheild spaced 1' from the the wall...to be placed behind the stove?
BeGreen said:The 8.5" dimension is for a corner installation I believe. Joe, is this also a corner installation? Maybe Mike or Corie can chime in here. The manual could be clearer by listing distances in the table for all the combinations of with shields and without, and with double-wall or pipe shield or not. And then also list the changes to these combos with an NFPA211 wall shield.
Backpack09 said:BeGreen said:The 8.5" dimension is for a corner installation I believe. Joe, is this also a corner installation? Maybe Mike or Corie can chime in here. The manual could be clearer by listing distances in the table for all the combinations of with shields and without, and with double-wall or pipe shield or not. And then also list the changes to these combos with an NFPA211 wall shield.
Well, I think the limiting factor is the single wall pipe. It must be 18" clear of combustible walls. So with or without heatshields you must follow that.
Now that image you posted begreen... it lists tighter rear clearances without heatshields and with single wall pipe.... that doesn't seem right.
stoveguy2esw said:as for the "e" measurement, if the stove is placed in a dead on 45 degree install with the proper clearances , the hypotenuse of the angle would place the flue at this measurement.this is why the measurement of the pipe is farther than in a flat wall installation.
BrotherBart said:stoveguy2esw said:as for the "e" measurement, if the stove is placed in a dead on 45 degree install with the proper clearances , the hypotenuse of the angle would place the flue at this measurement.this is why the measurement of the pipe is farther than in a flat wall installation.
BB - Eagerly awaiting somebody using the word "hypotenuse" on the local building inspector. hh:
