stoveguy2esw said:
kcgoat said:
i am posting for a handicap friend ,who has a 25-pdv stove ,this stove blows cold air ,it is in a 10 by 40 foot trailer ,it is only slightly warm to touch ,you can sit necked on this thing ,have tried adjusting the control every which way ,no heat ,it stays around 50 degrees in trailer, please help
ok, need to find out some particulars about the unit and the install, if the unit is not getting even hot to the touch then somthing is amiss. would be best if you could give me a call (preferrably if you can be at the stove) at 800-245-6489 , ask for mike. 25-pdv should not have any trouble heating that size area, so somthing isnt normal , if you can call me while you are at the unit i can direct you from there to correct whatever is causing this. seriously , give me a call i can figure this out.
the stove is now working ,i had pushed ,the preset buttons ,which he kept saying were not to be touched ,because he said they were factory preset , but after pushing them and setting at 9 and 5 it works flame is up heat is working ,will call tomorrow to verify what i did when i am in front of stove,,,,,, thank you
