Embed pictures inside posts instead of thumbs.....
backpack09
554
Rochester, Mass
OT-
Would it be possible to make inserting pictures directly into posts possible? I find it much easier to read through a post if there are pictures that I do not have to open in seperate tabs to look at.
You could easily (i think) put a size limit to the pictures to keep the format of the forum readable.
Just my Opinion :) I like being able to post my pictures that way to rather than plugging up your server with our uploads.
I thought we did that already.......Oh, it might only work in certain forums - I'll make it happen here.......
I may have to disable this if it is abused, or move it to just the picture forum, since it might really clog up the threads.
Code:
 [img]  image url here.....  [/img]
But you do have to know where the image is....
so
Code:
 [ATTACH=full]206850[/ATTACH]
should make it work below.....
If you see another copy of the pic below, that means it works even without the tags,
(yes, it does......that could be a problem)....
[url]https://www.hearth.com/images/2006logofront.jpg[/url]
Now how about if we use a regular set of url tags around it, like paste the pic link and then use the <a> thingy on the menu above:
[url=https://www.hearth.com/images/2006logofront.jpg]https://www.hearth.com/images/2006logofront.jpg[/url]
  • Embed pictures inside posts instead of thumbs.....
Just wanted to test. Pic removed so as not
to clog things up.
The linking to pictures is only if the pics exist somewhere else. There is no generic upload area. You have to either upload to a post - in which case they show as expandable thumbnails - OR - you can insert a full URL link such as
http://www.google.com/intl/en_ALL/images/logo.gif
the above link is
Code:
What if your picture is saved on your PC and not hosted somewhere else?
In that case, it is best to upload it directly here - inside the post.
Or, you can start and account on google photos (picassa) or any other service - put the pics there, and then embed here....
In general, I upload my pics here using the forum "browse" button when creating or replying. You do have to resize, but there are lots of hints in other threads here on how to do that.
53flyer said:
Test: 3 different attempts to get the same piture to post. What am I doing wrong?
The board cannot handle spaces in the URL.
I think you have to go back to photobucket and rename the folder : "Wood Stove Pics" to "Wood_Stove_Pics" or "Woodstovepics" or Woodstove or something with no spaces.
Seems strange the forum software doesn't just change the space to a % or underscore, but it looks like it doesn't.
http://tutorials.photobucket.com/tutorial_84.html
talks about that problem in photobucket.....
They could change their code to not allow people to do that, or do a rename using the underscores when folks enter spaces.......
I suppose this forum software might have a setting somewhere I am not familiar with....when I have time I will check with the maker and see if we can convert that stuff.....
I think " " or something like that is a space.......
In HTML, a space is represented as %20 but the board tends to convert them to spaces.
So, the properly formed URL would be:
http://i205.photobucket.com/albums/bb16/flyer53/Wood%20Stove%20Pics/SierraAmbassador4700TECPIC2.jpg
Thanks for all the help. It's frustrating for me because, while not a computer guru, I'm not computer illiterate either and usually I can figure these things out. I've posted pics on other forums but I agree that this software must be different.
I took out all the spaces and entries but that didn't help. The tutorial I looked at didn't specify how to name photos but it did discuss folder naming. I couldn't figure out how to rename my current folder so I made a new one with no spaces. Then I tried to figure out how to move the pics to the new folder but it's not working yet and I'll probably end up just uploading them again to the new folder. It wouldn't take so long if I wasn't stuck on dial-up... Where's my DSL!!! Uggg
Webmaster,
I, too, am trying to put a photo (which resides on my PC, not out on the internet somewhere) into a post on this bulletin board. Your instructions on this were, "In that case, it is best to upload it directly here - inside the post."
Okay, I give up. How do you upload it directly inside the post? Is that the same as making it an attachment? HELLLLPPPPP!
DanCorcoran said:
Webmaster,
I'm having EXACTLY the same problem. ARGH!
When you are on the screen where you compose your post go down to the place to insert "Attachments". Click on "Browse" and select the picture from where it is located on your PC and it will insert it into your post when you hit "Submit".
DanCorcoran said:
Webmaster,
There is no attachment option in the 'fast reply', you must use the 'post reply', 'quote' or 'edit' option to post an attachment. Here's how:
https://www.hearth.com/econtent/index.php/forums/viewthread/18669/
and some greater details on how to size pics, etc.:
https://www.hearth.com/econtent/index.php/forums/viewannounce/27_2/
Just testing
IMG_0722
This is the way that has been working for me.
I first upload the the picture to a photohost. Then I click on the picture and open it up. Using firefox I right click on the picture the select "Copy Image Location"
If you are using internet explorer you have to right click on it and select Properties then copy everything after Location
It will look like this
http://photos.cubfest.com/albums/userpics/10036/IMG_0975. JPG (I put a space between the . and jpg tag so it would show up the typing. Remove the space it it will show the picture in the form)
Usually you have to highlight that and hit the <img> tag from the top of the post new reply.
But on this form you do not have to. All you need it the picture location and have it hosted on a online picture form.
http://photos.cubfest.com/albums/userpics/10036/IMG_0975.JPG
Billy
