mtalea said:I am a contractor also......application is siding and it was just a wondering question....I read that it last for max. of 20 years.....if that is the case why use it,go back to felt instead
wrenchmonster said:Hogwildz, I'm really not trying to pick fights with you on the forum, so please don't take this the wrong way, but you are wrong sir. The fact of the matter is that Tyvek has its fair share of problems. It really hasn't been out in the field long enough for proper evaluation. It's not the miracle barrier everyone thinks it is. Tar paper can fall apart, sure, but there are lots of things involved. How long has it been there? What kind of siding protected it? Etc. Besides, distrubing the siding can be the cause of the tar paper falling away, if you weren't tearing off the siding, it would remain intact underneath. I've seen tar paper 30+ years old in just fine condition. To make the blanket statement that it all falls apart is not accurate. In fact, for cedar, I wouldn't use anything but felt.
-Kevin
coldinnj said:There are materials to be used as a vapor barrier under siding that are engineered properly. When installed correctly they will allow the moisture to escape out from it but will not let the moisture come in from the outside. On the idea of a one way valve. At one time Tyvek was suppossed to do that. I do not know if it currently made that way. Remeber a happy medium must be used to make a house tight BUT not to tight. Tyvek when used properly is a good material. However many contractors do not use it properly. Simple READ the Manufacturers instructions.
Many holmes are done with a vapor barrier on the insulation on the inside and then with a vapor barrier on the outside under the final sheathing surface. Think... Double Vapor barrier???? Is this Good?
coldinnj said:Ah Hogwildz
My favorite roof of all...
The best roof of all...
The longest lasting roof of all...
The most cost effective roof of all...
SLATE
Of course this is IMHO
But cared for with normal maintenance - couple of hundred years is not impossible. Just don't insulate up against it. Don't coat it. Let it breathe. And if a person doesn't know how to walk a slate roof then tell him to keep the f**k off of it.
As to cost wise, we had a pretty good price on getting it. We bought it directly from the quarries where it was made / cut.
Anyone have an old Parsons cutter laying around?
coldinnj said:My comment about double vapor barrier was rhetorical, just promoting food for thought.
Remember when PT lumber came out? Oh they bragged it was guarrenteed for 40 years... Sure was... Guarrenteed to - spit - crack - warp - check and if not retreated rot. I have yet to see any of it last better then 10 years without problems if left unretreated.
With time all materials seem to be found wanting for some reason or other. We think we find better and better ways until someone realizes that some of the old ways really weren't that bad after all. Hmmm maybe our ancesters were not so dumb.
wrenchmonster said:I think we're more in agreement than not Hogwildz. Every material has its strengths and weaknesses. Plenty of homes have been built without even tar paper. I just hate when folks think that they have to put tyvek over everything, when it really depends on the application at hand. I'm not a fan of it primarily from what I saw as a contractor. A majority of the jobs I did were re-siding homes that were built with the first generation LP T-111. In Portland, OR, T-111 would grow mushrooms on it. Tearing that off exposed tyvek, and underneath the tyvek was black mold on the sheathing. It's a hard pill to swallow for a homeowner when you tell them they need new sheating and it's going to cost an extra few thousand dollars. Not to mention in the process of replacing your sheathing some drywall might crack. I always warned customers up front about anything I find wrong needs to be fixed or no warranty from me. Anyway, that's why I've never been a fan of tyvek. I have not used it on any additions made to my house.
I've seen the crumbling felt as you describe, I wasn't insinuating that never happens, just that it's not the rule. I guess you don't like working with felt, it's okay to me, not that big of a deal. Well see how tyvek does in 50 years, until then I certainly won't use it on my projects.
Paint cedar? Come on Hogwildz... you can do better than that.![]()
-Kevin
coldinnj said:The slate with the diagonal lines we call ribbon slate. It is what I would buy by the skid and pick through to get the good ones out of. Ribbon slate did not hold up as well. The clean slate did not have the lines and lasted much better.
BTW one problem with slate was when removing it... you had to be careful, slate dust is as slippery as oil.
I have the proof...
After falling 2 1/2 stories off the roof because of a**hole helpers and my own stupidity. Went back up after some healing but a stronger respect for the friction coefficient after that.
I still have about 600 clean 6 x 12 slates about half of which have corner angle cuts, for looks, the others square cut. Anyone interested?
coldinnj said:no bust up at the time that I knew of. To bullheaded to go to a Dr. and let them check me out. Hit dirt instead of the concrete front steps by about 10 inches. Of course my back is shot now. May have been that. Don't no. Could have been a contributing factor though.
Whole reason I started my slide was because, while on a not really walkable roof, one of the guys on the roof while ripping it off, hit a bat, killed it with a hammer blow, I didn't know it, then he surprised me by throwing it at me and yelling look out. That started me doing the dumbest thing. I turned my back to the roof, and started sliding. With my back to the roof I couldn't punch through with my slate hammer and next I was immitating a bird - just not very well. That was about 30 years ago. And here I was on another nonwalkable 2 days ago. I guess we don't always learn with age.
BTW the largest roof I ever did was a reroof from slag to rubber job. 30 acres in size. Now that was a roof!
