eliminate ash draw plug/plate ?
carinya
142
ohio
I don't use the ash draw on my 13.
Being a mild day in sunny Ohio I have cleaned out the ash from the firebox & removed the ash plug/plate & replaced with a brick. The protruding "handle" on the plate is always a pain in the ash when I'm shoveling.
Anybody tried this before ? Pros ? Cons ?
Am I playing with fire ? oops, sorry :cheese:
Makes sense. I see no downside. There are evangelists that will line up on both sides of the ash drawer debate, but if you don't like it, don't use it.
I've cranked up a fire.
Stove top is 550. I pulled out the ash drawer & am able to touch the brick where it covers the ash hole but the metal bottom of the firebox is to hot to touch.
I guess those bricks are good thermal insulators :smirk:
the side where the ash plate had been had a tell-tale glow in the coals at the end of the burn.
I'll see if an accumulation of ash will block the air infiltration
I'm debating doing the same thing. First season w/ my 30 and I'm sick of that plug already. I never use the ash drawer and have extra firebrick lying around that would cut to fit perfect to eliminate it.
pen
I modified the plug on my 30 so it's flat. Nothing to get in the way now!
Getting ash in the gap around the new brick seems to have done the trick but I'll keep your mod in mind
