I bought the NorthlineExpress 4-ton log splitter and it came this afternoon, but the manual uses terms for electrical specs that are total Greek to me. Can anybody interpret for me?
1. It says "Connect the main leads to a standard 120V electrical supply which has protection devices of under-voltage, over-voltage, over-current as well as a residual current device (RCD) which maximum residual current rated at 0.03A."
Hah? I haven't the faintest idea what any of that means, and don't even want to know. Can I assume the outdoor grounded outlet for power tools on my house likely meets those conditions?
2. Also, it says, "check that there is a regulation differential switch upstream." All righty. Might this be what we call a fuse or a circuit breaker?
3. And then "Be sure the extension cord is no less than 2.5 mm to allow sufficient current flow to the motor." Am I right that that's the equivalent of a 10-gauge extension cord? Really? The manual says this tool draws 1500 Watts, which by my calculation is 12.5 amps. Why would you need a 10-gauge extension cord for that?
4. Then it says I should "Ground the log splitter" and "prevent body contact with grounded surfaces, pipes, radiators," etc. the usual stuff. How on earth do I ground this thing? To what and with what? How are you supposed to ground a tool you're using out in the yard or in a wooden (natch) woodshed?
Any electro-Greek speakers around here who can translate any of this stuff for me?
