Anyone have pics of their near boiler plumbing. I will be starting the plumbing on an eko 40 soon and pictures are like a 1000 words for me .
Cheers Huff
Cheers Huff
stee6043 said:This is probably the best shot I have (boiler on right). The zone valve (with copper) is not part of the near boiler piping, I was just using it as a holder. And the Taco pump (both actually) is in fact mounted in the wrong orientation in this photo. Other than that, it's pretty much as-is on my system.
twitch said:I have a few pics. Click the link in my signature. I have a Tarm, but I'd think the piping would be similar.
twitch said:Huff - They are 1-1/4 tees down to 3/4 for the aquastat well. The valve is a Taco NO zone valve being used the same way an automag would be.
huffdawg said:twitch said:Huff - They are 1-1/4 tees down to 3/4 for the aquastat well. The valve is a Taco NO zone valve being used the same way an automag would be.
1 aquastat for the circ p/p and 1 for the emergency zone dump valve?
Huff
huffdawg said:stee6043 said:This is probably the best shot I have (boiler on right). The zone valve (with copper) is not part of the near boiler piping, I was just using it as a holder. And the Taco pump (both actually) is in fact mounted in the wrong orientation in this photo. Other than that, it's pretty much as-is on my system.
Thanx Stee .I guess you put a coupling above the danfoss afterward . Just thinking about ease of getting it out if it fails. What do you mean wrong orientation! Supply and dicharge backward.
Hows everthing working now. How long does your storage last after its heated . What temps are sending to your HX
Cheers Huff
wood eater said:stee6043 said:This is probably the best shot I have (boiler on right). The zone valve (with copper) is not part of the near boiler piping, I was just using it as a holder. And the Taco pump (both actually) is in fact mounted in the wrong orientation in this photo. Other than that, it's pretty much as-is on my system.
your expansion tank look small with all that storage, is everything running o.k.
woodeater
stee6043 said:huffdawg said:stee6043 said:This is probably the best shot I have (boiler on right). The zone valve (with copper) is not part of the near boiler piping, I was just using it as a holder. And the Taco pump (both actually) is in fact mounted in the wrong orientation in this photo. Other than that, it's pretty much as-is on my system.
Cheers Huff
Huff, I didn't install shut-off's at teh Danfoss since the cover comes off to replace the "moving parts". I have shut-off's in every direction within a foot or two of pipe so I can isolate it pretty well to change out the thermostat if required.
Both Taco pumps in my picture need to be rotated 90 degrees to run properly.
I can run 16 hours roughly on storage. I can heat effectively down to about 145 degrees running through the HX...
taxidermist said:click on my blog I have pics let me know if you need any explaining
Rob
