Yesterday i had some free time and took some photos of cooking a bird https://www.hearth.com/econtent/index.php/forums/viewthread/31866/ in the boiler as well as some general photos of my system including a primary air modification that has been working well.
The eko 60 I purchased was one of a number that were made exploring the viability for sale for outdoor use, more like you would think of a normal OWB. The units were not able to have a price point that making them a viable business venture. A stainless frame was built to hold the boiler and the all insulated shell surround and roof. It had a 100 gallon tank with expansion and circulating pump inside as well. All a peson had to do was connect electric to one place and hook up plumbing to two points on the internal tank and you were good to go. I used it as an outdoor configuration for a season until I got the barn built. The unit replaced a Heatmor that I had found a buyer for after finding out about wood gassifiers. After the barn went up the 100 gal. internal tank was replaced with an external 250 gal. insulated propane tank and the expansion tank installed inside boiler shell. Another 500 gallon storage tank is located in the house located 100 ft away from barn.
When I built the barn this year I made an opening the shape of the face of the unit and pulled it flush with the outside wall. Aluminum flashing seals and makes the connection to the wood siding in the forbay area where its installed. I like it because I can load with having to worry about smoke issues etc. I can treat it more like I did my OWB with the exception of the dry wood diet needed for the gasser.
First a general view of the Eko installed in the forbay of the barn. The boiler is behind the grey doors in the lower right hand side of the photo, you can also see the chimney exiting the roof. Also a closer up showing the boiler behind the doors.
<url> http://smokelessheat.com/Media/primaryair/barnview.JPG </url> <url> http://smokelessheat.com/Media/primaryair/withdooropen.JPG </url>
These photos show what it looks like inside the barn. The one photo shows the boiler enclosure with the insulated removable side panels off and installed. There are removable panels on the opposite side identical as to the ones showing on this side and doors on the back side like the ones covering the front loading area. In the center on the open panel picture is a draft meter mounted on the side wall of the boiler. I have been experimenting with different draft control as I had lots of trouble with too much draft. How i'm currently configured is working well. without the draft meter Dwyer Mark II i would'nt have known what was going on.
<url> http://smokelessheat.com/Media/primaryair/insidewithopen.JPG </url><url> http://smokelessheat.com/Media/primaryair/insideclosed.JPG </url>
Going back to the front of the boiler it shows a view with the pressure fan cover closed and removed.
<url> http://smokelessheat.com/Media/primaryair/frontcloseclosed.jpg </url> <url> http://smokelessheat.com/Media/primaryair/frontwithoutcover.jpg </url>
Here are some closeups of the actual primary air modification. It's a 1/4" rod bent in a L shape 7"x 2 3/8" welded to the existing slider. The slider bolts are loosened and two set rings are placed on ends of the adjuster rod. Indicator marks are made after the rod has been installed. I find rod sometimes needs to be tapped with a hammer if the boiler idles much as it can collect some creosote buildup.
<url> http://smokelessheat.com/Media/primaryair/frontwithtape.jpg </url> <url> http://smokelessheat.com/Media/primaryair/sidewithtape.jpg </url>
<url> http://smokelessheat.com/Media/primaryair/slidercloseup.jpg </url> <url> http://smokelessheat.com/Media/primaryair/externalrodclose.jpg </url>
<url> http://smokelessheat.com/Media/primaryair/sliderodlowview.jpg </url> <url> http://smokelessheat.com/Media/primaryair/sliderexternalstraight.jpg </url>
My secondary tube had also worked it's way out at one point. I made a little piece of angle and sheetmetal screwed it together after tapping back in place. Also the cover where the pressure fans are mounted was kind of flimsy so I fastened a small angle across the back side to stiffen things up.
<url> http://smokelessheat.com/Media/primaryair/secondaryairmod.jpg </url> <url> http://smokelessheat.com/Media/primaryair/backsideofcover.jpg </url>
