Hi all ,I'm in need of some help ,actully the guy that owns the Eko 60 is in need of help .
I'm trying to help him but I've come to a wall .
His Eko 60 will burn for ten minutes or so with good fire coming out of both lower nozzles then one of the two will go out and the other will stay going so so . To get it to burn good again I open the loading door push the wood around a bit get both nozzles covered and it will burn good for another 10 or 15 minutes . The wood he has is nice dry and split oak but its only 18 inches long which makes it hard to cover the nozzles good ,I cut some of them in half so the nozzles could be covered better and it worked so so . Can't seem to get it to run past 70 on the read out .I adjusted the primairy air from low to high and back to low also the secondary ,just can't get both nozzles to stay burning good .
I have a Tarm 60 which only has one nozzle ,no issues like this at all ,load it forget it for 12 hours . I've run this for ten years now so I have a bit of experenance with gasification ,I also helped install five of the Eko 40s . We had some issues with them but only because they were trying to burn kiln dryed scrap wood .
Thanks Mike Neeb
Thanks Mike Neeb
