Hi - I've been reading threads in this forum for several years, as I worked with a major contributor to the forum (Eric Johnson) who had lots of good things to say about the community. Eric advised me to move from a standard wood boiler to a gasification boiler and seeing as he was using an EKO, I ended up buying an EKO 25 and have been pretty happy with it - particularly after I got the wood drying aspect of things correct.
I've got the boiler in my basement and have had one working (on my second one) very well for several years. Over the summer I cleaned the boiler pretty well and left the doors/flap open to reduce condensation. I fired up the boiler for the season last weekend. Just after I closed the bypass flap to initiate gasification I tried to pull the handle to turbulate the heat exchange tubes (my routine, so that I turbulate every day), and found that the turbulating handle moved a little bit and then got stuck. Now, the bypass flap had been wide open all summer so the turbulating handle had been in position for that flap to be open - but now I can't move the handle more than an inch or two and I can't get the flap open more than an inch or two.
I proceeded with the assumption that creosote or ash or something was gumming up the heat exchange tubes so I threw some potatoes in the boiler (I tried this several times) as this had been a help previously when the turbulator had gotten sticky. No soap. I next removed the back/top cover to expose the heat exchange tubes - and I didn't see anything to account for the turbulating action being blocked. Keep in mind that I didn't take anything apart - I was just looking. The guy who sold me the unit advised me to pour some charcoal lighter fluid on the tubes and fire up the boiler - I guess with the idea that any creosote would get burned up. I did this a couple of times - again, no soap. Throughout this - I've seen no increase in the range of motion of the handle.
The space holding the turbulator and tubes is so tight that I'm hesitant to start dismantling things - but that's probably what I'm going to have to do next. Keep in mind that I'm not a mechanic or engineer and not particularly adept at these sorts of things but I'm willing to try to fix things myself, at least if the process makes sense to me.
The good news for me is that I can get the bypass flap open enough to get a fire started so I can operate the boiler and heat my home. The bad news is that I need to solve this heat exchange tube cleaning issue before things start getting too, too hot with the outflow to my chimney. Another piece of good news is that I still have my old EKO 25 in the basement - to provide spare parts if needed. I can't seem to locate any diagrams of the turbulating mechanism or how to easily remove the heat exchange tubes - so if that's my next step i may put that off for awhile while I think my way through it. I'm looking for any advice from this group. Thanks for anything at all - and happy holidays to you.
![[Hearth.com] EKO 25 - heat exchange tube help [Hearth.com] EKO 25 - heat exchange tube help](https://www.hearth.com/talk/data/attachments/304/304036-3726118ce1f50f0dd8e384058a413179.jpg?hash=YBNixrWzsM)
