I see a lot of people here argue about efficiency and it comes up a lot in fan discussions and such so I figured I’d cast a little light from a combustion engineer’s standpoint.
There are two types of efficiency that you should really care about, heating efficiency and combustion efficiency. These while linked are separate efficiencies.
Combustion efficiency is how completely you are burning the piece of wood in your stove. This means if you were to do a stack test on the stove while burning, the stove with the least amount of un-combusted material (except for ash) leaving the flue would be the most combustion efficient. However, this is NOT the same as heating efficiency.
Heat efficiency is how much of the wood’s energy actually stays in your house versus how much goes out of the stack. More efficient stoves have lower stack outlet temperatures. This is because the sensible heat loss out of the flue is the biggest cause of stove inefficiency.
Be aware, good seasoned cordwood cannot really be burnt above an efficiency of 77-78%. There are limitations on condensing flue gas (creosote), complete combustion/good mixing and moisture losses that prevent better heating efficiencies.
Total Heating Efficiency = Heat Input – Dry Flue Gas loss – Moisture Loss – Unburnt Carbon Loss – Moisture in air loss.
The only real way of increasing heating efficiency is to lower your stack temperature assuming your stove has good combustion efficiency.
