a 90 is a 90....it's always counted as 5
Count the equivalent vertical length (EVL) points for the entire mock run as follows: For each 45 degree elbow, add 2.5 EVL; for each 90 degree elbow or Tee, add 5 EVL; for each horizontal foot, add 1 EVL; and for each vertical foot, add 0.5 EVL. Add all the points together.
If the sum is under 15 EVL and you are under 3,000 feet in elevation, you will use the three inch pipe. If you are over 15 EVL use the four inch pipe. You would also use the four inch pipe if your EVL is over 6 and you are above 3,000 feet. You must use the same size pipe throughout
I was reading the Palazzetti manual and it stated the maximum horizontal run is 10' therefore if I used one 90 tee or elbow the vent for this stove would have to terminate as a horizontal. Is that correct?
The minimum termination clearances were not all that great for this stove. 4' to the side or below a window or door and 1' above. I was under the impression that with make-up air the euro stoves and the better quality stoves the termination clearances were as little as 3-4"
I was reading the Palazzetti manual and it stated the maximum horizontal run is 10' therefore if I used one 90 tee or elbow the vent for this stove would have to terminate as a horizontal. Is that correct?......
How long would the horizontal pipe be if it stopped just as it exited the outside wall?In my house the ideal spot for the stove is a small 3x5 alcove. The stove would be no more than 2-2.5' from the outside wall. In order to vent through the wall the pipe would need a 90 right from the stove, manual says 10' horizontal run max, if each 90 is the equivalent of 5' of run, how could I then have another 90 outside before I went vertical?
