EF-2
charger1966
107
UpState New York
Can anyone tell me the symptoms of a Low Temp Sensor going bad? I think that my stove has a problem with one. Also can anyone tell me where to find it in the machine? Thanks, Lance
Hello
If the Low Limit switch goes bad and stays open, then the room blower will not turn out to blow the heat out.
What is wrong with your stove?
Well thank you for that information. After doing some reading and testing I found that the vacuum pressure switch has failed. My stove keeps going out and after bypassing the vacuum switch it runs like it did when it was new. One is on order now. I'll let you know after I install it how it worked. Thanks again. Lance
