If you want more help , you will need to give more information.
The manual I have says the following :
B) Flame stabilization phase
DISPLAY SHOWING “FLAME LIGTH” : in this phase the ignitor goes automatically in OFF status; the flow of air goes at a value set by parameter TF10. The functioning of the auger is set by parameter TF08 the flame has few minutes (TF09) to get stabilized.
During this working phase, which duration is measured in minutes (TF09), a check is done on smoke temperature. The system memorize the smoke temperature T0 at the beginning of this phase. Then, every one minute, a test is done to be sure that the smoke temperature increase regularly; in the contrary, the display will show “AL11 – WRONG FLAME”
![shade smirk >> >>](/talk/styles/default/xenforo/smileys/shade_smirk.gif)
( I would not trust the TF numbers given here without confirmation.)
By setting the display to <status> , you will be able to double check the error by watching the smoke temperature at it starts up.
After the stove changes to this final phase you can watch the exhaust temperature rise until it reaches the trigger temperature for the 'working' phase. If it doesn't then it will be because there are not enough pellets burning .
Not having confirmed which TF parameters are used for the auger while in start up mode , my stove is usually short of pellets for this final start-up phase , but instead of being frustrated by the ERR AL11 message , I systematically add a fist full of pellets to the burn pot before I press the <on> button.
Another reason for a "no light " is that the auger started empty. If the stove stopped because it ran out of pellets , the auger will be empty. Two solutions : run the auger in <status> mode or just add
two fistfuls of pellets before starting.
