Ecosmart LED BR30 from home depot
Highbeam
20,940
Mt. Rainier Foothills, WA
So I bit the smallish bullet and swapped my CFL BR30s that I hated hated hated for their long warm up time with these LEDs in the living room can lights. The CFLs were soft white, 15 watts, and had very good color once up to temp with 690 lumens. The LEDs were also soft white but only 9 watts and 650 lumens.
These are the real deal. Excellent light quality and instant on. Plus, the price was 10.88$ each. Surely there were some instant utility rebate subsidies since regular CFL BR30s are over 6$ each.
Anyway, I'm very happy. Not just with the reduced power use but with the instant on and high quality light. I'm doing a kitchen remodel and will be using LEDs for the lighting. At 10$, there is no downside that I can see.
Reactions: jharkin
Where did you find them for that price? The cheapest I've seen are around $16.00 per bulb on the Home Depot website.
It's great to see the prices coming down on these lights. We have a couple Feit's that I got from HD as a test in our pantry track lights. They are working out great so far. First time I have seen/used an LED lightbulb replacement that I like. Works with the regular dimmer too.
At home depot. Individually pakaged. The "lense" feels like plastic. I was a vicitim of one of those entry way displays where they were located.
Now if the home depot would only stock the 1.5 gpm showerheads that are cheap or free from the utility. They seem to have a commitment to one or two brands.
I think those are the same bulbs I used when I replaced the eyeball can lights in my kitchen two years ago. Very nice bulb, only downside is a very slight turn on pause.Light is almost as good as the Cree CR6 but those dont work in all fixtures.
Thats a fantastic price, I think I paid $20 or $25.
EDIT: I went back to look, I paid $29 each. Thats an AMAZING price you got!!
I found this add not long after I posted my question above. I pulled the trigger and bought 12 of these and am looking forward to replacing all my incandescent BR30 bulbs in the recessed cans in my kitchen. I also have one in each of my bathrooms which I'll now replace with one of these LED's. The total was about $160 bucks but I hope they'll pay for themselves over the course of 5 maybe 6 years. I have 9 recessed cans in my kitchen and it seems I'm replacing one of the incandescent bulbs about every 3-4 months. Probably because I use the cheap ones that cost $4 -$5 bucks. Anyway, thanks for posting this info.....I'll try and make a point to post my experiences with these new bulbs once I install them.
The slow to turn on and long purple warm up are the reasons I went to LED. I was particularly sensitive to the instant-on time when I installed the first one as a test. I could detect zero time between switching them on (no-dimmer, just a switch) and full power. Maybe they improved?
If you can mail order them for 12.50 each then the only subsidy I got from my utility was 2.50$. The cost is actually coming down. From 30$ to 12.50 in two years seems quite good.
Well I received my LED lamps Friday afternoon and promptly replaced all of my incandescent bulbs in my kitchen. I've found they have a number of advantages. One, they're instantly on and have pretty much the same color light as regular lights. I think they're slightly brighter and definitely run much cooler in that I don't notice any heat being generated like the old bulbs.
However, I have discovered two serious drawbacks that I'm hoping I may be able to rectify. One, they don't dim nearly as low as my regular bulbs. For some this may not represent a significant problem, but for me it is as I often times like dimming my kitchen very low. Secondly, and this is the biggest problem, the lights seem to interfere with my television reception as I have an "over the air" rigged tv sitting on my counter top right near my dimmer switch.
I'm hoping that if I buy a better dimmer, both these problems may be lessened to an extent. Does anyone know if there's a particular kind of dimmer recommended for LED lamps? The one I have now is a simple toggle switch style and so I am curious if there's such a thing as a "shielded" slide type or some other style that might dim lower and not mess with my digital tv signal. Any help would be appreciated....
Despite these drawbacks, I do like the lights and suspect I'll save significantly given what little amount of watts these lamps use.
While I do not have any dimmers in the house, I do use an antenna for all of my television and have noticed zero interference. Different dimmers work in different ways and I suspect the dimmer itself is your problem.
So when these dim, does the light become redder/browner like an incandescent or is it the same color but less bright? I may add a dimmer because, I can.
Yep, it's the dimmer I think....I did a little research and there is such a thing as a dimmer switch specifically for LED lights. If you use a regular one it won't dim as low and may even cause a strobe light effect in the lights themselves according to what I've read. I think I just need to replace the right dimmer and hopefully I'll be all set. I'll post the results once I change out the dimmer.
Regarding your color question when dimming, they seem to work the same as incandescent lights in that they do seem to get redder/browner....
It seems odd that the dimmer would affect tv reception. Over the air is all digital now. I just tried a test with our kitchen tv that has a simple dipole antenna. The dimmer is about 12 ft away, but on a different circuit. No interference noted.
Highbeam, this is with an older Lutron dimmer. Our LED lights (Feit) do not go reddish as they dim. The light strength simply decreases. I did note that at the very lowest setting the lights flicker. Suspect this is the dimmer. Maybe it's the candlelight function. ;lol
My dimmer switch is right next to the TV and just above the receptacle in which the tv is plugged in. I think given the nature of digital reception (meaning it bounces off of practically everything in a house depending upon signal strength) it could be messed up because of these new metal encased LED lights. If I turn the light off or nearly off, my reception becomes normal again. ON PBS channels (which are UHF), if I turn the lights up full blast the reception is great. We'll see how this shakes out once a new dimmer is installed. Of course, these dimmers are significantly more expensive than regular ones....
Interesting, this almost sounds like RFI interference from the dimmer. I wonder if it is directly affecting the receiver circuitry in the TV? I'll be curious to hear if the new dimmer fixes the issue.
Another little tidbit is that my land line phone was also out of service for a day or so this weekend. And yes, the cordless phone is right next to the switch for the recessed lights. However, the other phone, which is non cordless, is at the other end of the house and it was knocked out too. I assumed it was just some other issue as we did have a storm roll through over the weekend. The phone is back up and working okay but I'm beginning to wonder if all this isn't due to the switch as well.
Here's a copy and paste from the Lutron website regarding one of their CFL/LED specific dimmers. Note that part of the way down they mention that this particular model (the Maestro) has "superior suppression of interference with radio and TV." I can only take that to mean that dimmers can in fact interfere with television signals. Of course these puppies aren't cheap....
Features
  • Maestro offers a full range of designer light controls, fan controls, sensors and timers that allow you to adjust your lights and fans from anywhere in the room and even outside your home
  • C•L® models for dimmable CFL and LED bulbs are available with or without occupancy sensor; these models have HED™ Technology, which improves dimming performance of these bulbs
  • Models available with eco-dim® feature (dimmer guarantees you at least 15% energy savings compared to a standard switch), including a model with an occupancy sensor
  • High-performance personalized light control with additional advanced programming options
  • Dimmers offer customizable delayed fade-to-off, which lets you leave a room before the lights go out
  • LEDs glow softly in the dark for easy dimmer location and show preset light level when lights are off
  • Multi-location dimming compatible with 3-way wiring for easy installation and retrofit
  • Add companion dimmers to dim from up to 10 locations
  • Power failure memory (Maestro remembers your settings even after a power interruption)
  • Superior suppression of interference with radio and TV
  • Matching Claro® gloss or Satin Colors® wallplates available for 1-gang up to 6-gang sizes
Most dimmers (other that pure rheostats) can cause RF interference. I had to remove one dimmer because it affected the nearby phone line and interfered with my DSL (not the wireless, the incoming DSL signal).
As for digital vs analog TV, neither is inherently better or worse for interference, both use the same frequencies (although in most regions DTV is UHF, some areas still use VHF) digital has much lower signal strength so could be more susceptible to interference, depending on the interference type and the error-check circuitry in a particular TV.
TE
I went and bought four more of the ecosmart BR30 LEDs for the rest of the cans in the house along with 9 more HALO can fixtures to put up to replace the non-can kitchen fixtures. I chose to use can fixtures with an edison base vs. the dedicated LED cans since I like the ecosmarts so much.
While at the store I picked up the latest 60 watt Equivalent Cree LED light bulb to put in an outdoor fixture. 6 bucks. Works great too with no warm up delay.
I'm addicted. I now consider CFL to be stupid technology and do not expect to buy any more.
Anybody want 10 CFL BR30s? Work great, well, as great as a CFL can!
Well I installed an LED specific dimmer this weekend and it didn't entirely solve my RF interference issue. I am now able to turn the lights on a bit of a brighter setting before the interference actually seems to effect the tv signal. I'm also able to lower the lights a bit lower than with my previous dimmer. so all in all, a bit of an improvement but it didn't solve my issue entirely. Here's the dimmer I installed, same as the one referenced earlier in this thread:
http://www.amazon.com/gp/product/B004DZOMKC/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
I share all this so that anyone considering purchasing these LED lamps knows that there are some things to consider before doing so. All in all, I'm happy with these lamps as they're certainly much more efficient than regular BR30's, are somewhat brighter, and are much cooler in terms of heat generation.
I wonder if you had just put them on a switch if you would have this problem?
Maybe not, but I want them on a dimmer as I like to be able to adjust the light level in the kitchen. Creates a better mood for party situations. Also, as mentioned above, I believe all dimmers, due to their very design, create some RF interference.
I wonder if you could wire some chokes in on the wires.
It's in the kitchen. There must be arti_chokes nearby. ;lol
Reactions: Highbeam
