SolarAndWood said:Wait for a good wind storm?
firefighterjake said:hope for either a good windstorm or a winter with heavy snowfall
CountryBoy19 said:Looks like that might be simple to pull down. There doesn't seem to be much of a hinge holding it up there. Is it low enough that you could tie some sort of weight to a rope and throw over it then hook to a truck/winch/tractor and give it a good yank?
zapny said:I have a small anchor (15-20 lbs.) with about 100 feet of rope, the question is can I throw it up and around then pull down with the winch on the rhino. Hate to a the anchor hung up.
zapny said:CountryBoy19 said:Looks like that might be simple to pull down. There doesn't seem to be much of a hinge holding it up there. Is it low enough that you could tie some sort of weight to a rope and throw over it then hook to a truck/winch/tractor and give it a good yank?
zap
Battenkiller said:zapny said:I have a small anchor (15-20 lbs.) with about 100 feet of rope, the question is can I throw it up and around then pull down with the winch on the rhino. Hate to a the anchor hung up.
Listen, Hercules, if you can toss a 20 pound anchor that high, you need to be training for the Olympic hammer throw. :lol:
Seriously, no need to throw your shoulder out. Just find a heavy hex nut and tie a real long string to it. Tie that string to your rope. Toss the nut over the branch and grab it when it comes to the ground. Then just pull the string until the attached rope comes down to ground level and you in bidness. That's how I hang my food bag when I'm camping to keep the bears away from it.
Probably can pull that one down by hand, looks like its barely hanging on.
bsearcey said:Good luck. Like I said though, I wouldn't purchase that stuff for the few times you may use it. I'd personally go with a bank or pyramid sinker and some nylon string.
gzecc had a real good suggestion using the fishing pole.
How high would you say that is? Looks like 30' or more, but pictures can be deceiving.
zapny said:I would like to get this down if possible it's in a area that I would like to work, any ideas?
zap
smokinjay said:zapny said:I would like to get this down if possible it's in a area that I would like to work, any ideas?
zap
LOL Dont do it!
zapny said:smokinjay said:zapny said:I would like to get this down if possible it's in a area that I would like to work, any ideas?
zap
LOL Dont do it!
If things go well getting all the maple out tonight plus some stacked, I'll go back in and get the dead tree plus this Wednesday latest Thursday.
zap
Research "spud gun" on the net, zap. Or for a cleaner search, try "spud gun antenna launcher." This would separate out a lot of the nut cases. It's a big field. These little devices, often/usually pneumatic, will pull a string way higher than you'll ever need. String pulls rope, etc. Radio amateurs use these to get wire antennas waaaaay up in the trees for better reception. BTW you can control pressure and thus, height. This is much better than throw bags or even slingshot methods. Much over 20-30ft, it starts getting hard- but not with these things. Buy one relatively cheap or build your own out of (mainly) PVC pipe. BTW often a simple bicycle pump will suffice for pressurizing the chamber.zapny said:CountryBoy19 said:Looks like that might be simple to pull down. There doesn't seem to be much of a hinge holding it up there. Is it low enough that you could tie some sort of weight to a rope and throw over it then hook to a truck/winch/tractor and give it a good yank?
zap
Cluttermagnet said:Research "spud gun" on the net, zap. Or for a cleaner search, try "spud gun antenna launcher." This would separate out a lot of the nut cases. It's a big field. These little devices, often/usually pneumatic, will pull a string way higher than you'll ever need. String pulls rope, etc. Radio amateurs use these to get wire antennas waaaaay up in the trees for better reception. BTW you can control pressure and thus, height. This is much better than throw bags or even slingshot methods. Much over 20-30ft, it starts getting hard- but not with these things. Buy one relatively cheap or build your own out of (mainly) PVC pipe. BTW often a simple bicycle pump will suffice for pressurizing the chamber.zapny said:CountryBoy19 said:Looks like that might be simple to pull down. There doesn't seem to be much of a hinge holding it up there. Is it low enough that you could tie some sort of weight to a rope and throw over it then hook to a truck/winch/tractor and give it a good yank?
zap
Anyone remember "Real Men Eat Quiche"? Ah, anyway, this satire's main punch line was that it is OK to eat quiche so long as you cradle your shotgun and chainsaw in your lap while eating. :lol:quercus_kelloggii said:I like the 12ga idea!
