Earth stove tp40 low fuel feed adjustment?
JRD
10
Wyoming
Hello, I'm a newbie to the forum but been lurking for a few years.
I have been repairing old pellet stoves for a 3 years or so now and recently acquired a Earth Stove TP40.
It has been stored in a barn for years and needs a new window that I have ordered.
I have pulled the top off of it and cleaned the heat exchangers and baffle also give the burn pot a thorough cleaning inside and out.
I fired it up outside and let it run on high fuel for about a hour then set it to medium and ran it for about a hour. Seemed fine on high and medium but doesn't want to run on low.
On the low setting and convection blower off it will still loose enough heat that the snap disc will open and shut the stove down. I also tried adjusting the combustion fan draft plate and combustion fan speed settings on the control board. But no dice on low fuel setting
I did notice on the control panel in the circuits there are a couple trim pots wondering if anyone has experience with these old stoves? This controller is a OII 500s version
Thanks for any help
