![Dutchwest Damper Adjuster Install Dutchwest Damper Adjuster Install](https://www.hearth.com/talk/data/attachments/231/231608-d9df4333fdf1e1fd9292bfba2f6df920.jpg)
Hi folks.....just joined the forum and looking forward to the knowledge base and contributing my experience when possible.
As I was inspecting my Dutchwest 2462, I noticed the damper adjuster had deteriorated. I bought this stove new in 2000 so no surprise based on the location of this piece and the heat it takes.( pic attached). Does anyone know how to remove the damper crank to get this piece replaced? There are two square head bolts on either end of the crank. the one on the right goes thru the inner top into the damper crank and the one on the left goes into the damper operations rod. Not sure where to start and if the damper rod comes out first.
Thanks folks!
