Hi All - This is my first post. I just purchased a barely used 2004 Dutchwest 2462XL to heat my 2300 sq. ft. house located on the edge of the Berkshires in upstate
NY. The house is half post and beam 1870's, and half stick frame 1970's. Mostly one story, with about 350 sq.ft second story with a bed and bath. Insulation is not great. Most of the windows are old school, non insulated, but have storms.
So, I am about to do my first stove install. My XL does not have the optional bottom or rear heat shields. I have some nice big slabs of 3/4" thick Penn. black slate that I want to use under the stove and on the back wall. There are no side wall, or corner clearance issues. I know the R value of slate is minimal. I am looking for advice on what I should put under the slate to protect my combustible pine floor? As well as back wall between the slate and the Sheet rock.
I am planning to go straight out the back of the stove, and thru the wall using a Metalbest thimble, double wall black pipe, into 8'' insulated Metalbest SS chimney.
It is a pretty flat low roof above the stove and I don't want to encourage leaks, so I felt out the wall and up to be the best option.
I am really hoping that this will be my primary source of heat as I was slammed with propane costs last winter. If any of you might offer any insight
into my best path I would be very grateful.
Thanks!
Mark
Thanks!
Mark
