Durock discussion
WoodyIsGoody
1,437
Pacific NW Washington
EDIT: Thread extracted from hearth building post.
https://www.hearth.com/talk/threads/wood-stove-hearth-build.163800/
Ok but why doesn't it look like the old next gen? I could not care less about the name I just really need to know that the new stuff has the same r value.
The new stuff does not have the same R value! And that's a good thing! Doc needs R .39 to meet requirements. The old stuff would not work here. He got the new stuff. The product label indicates that, the label on the shelf indicated that, the salesman said they don't even have the old stuff anymore, Doc proved it when he weighed it, WHAT MORE DO YOU WANT?
I don't care if it has pink elephants on it, it's going to get covered up by thinset and slate. It's obvious he has the right stuff. 100%
At thos point it doesnt matter to me unless i have to buy sn extra sheet in the feild i just bought a skid of the stuff labeled next gen
Here's all you need:
(broken link removed to https://www.usg.com/content/dam/USG_Marketing_Communications/united_states/product_promotional_materials/finished_assets/durock-cement-board-submittal-CB399.pdf)
Straight from the companies mouth R=.39. The sticker on the product proves it's the new stuff.
You know damn well I mean the old next gen that was labeled as such. This may all be a game to you. But I do it for a living and honestly the sales people at lowes and hd generally have no clue. Before I will use and durarock that isn't labeled next gen assuming it has .39 I need confirmation from usg and i need a new msds sheet.
This is not about just this install. There will be a lot more this winter.
PS: the weight was 34#.
But my scale says I weigh 230.4 and I know that's not right! No way I'm that heavy!
So I would say 34 is a really rough number!
Reactions: bholler
What you are not getting is that there is still inventory of the old and the new product on the market with apparently no clear labeling to distinguish them as there used to be. The amateur DIY'er is not going to know the difference and a pro must know the difference.
What you are not getting is that there is still inventory of the old and the new product on the market with apparently no clear labeling to distinguish them as there used to be. The amateur DIY is not going to know the difference and a pro must know the difference.
Right. The first thing I though was how many houses have burned down because people used old stuff that was sold as next gen at the store here.
I'm glad it was the other way around and safer then the old stuff.
Reactions: bholler
LOL You'd like our scale. It always says I weigh a few pounds less than the doctor's scale.
Reactions: Doc C
Well thank you that does confirm it. I still will need to get an msds sheet on the new stuff but good to know.
I am glad it worked out sorry to give you a scare needlessly.
Reactions: Doc C
I doubt it. At least I can't find any of the old heavy stuff for sale anywhere. Not for a long time. It's all filled with perlite now.
I'm glad you did! Hopefully it will help alot more people in the future to not have the same issue.
Reactions: bholler
I just saw it at the local lumber yard Thursday.
No games, just the facts. There is no such thing as "old Next Gen Durock". If you are referring to the stuff that was actually painted "Next Gen", that's the same spec as the new stuff. Just different aesthetics. You need to go by the product label.
It's not clear why you don't trust the product label? I think you just like to create drama.
No it is not clear the product label does not say next gen like it always has. It does not list the r value so no help there from the label. And no if it is no longer labeled as next gen I need to get new documentation to carry in my trucks and submit for permits etc.
OK, go ask them to print out a product data sheet for you. ;)
Why do you act like this is all a big joke. I presented a valid concern to doc. Because that is not the product that I have ever seen from durarock that has .39. It turns out I was wrong and it was fine but all I am saying is I still need the documentation as a pro.
That's my point.
So you are telling me to go get the old data sheets that I already have reprinted? How would that possibly benefit me at all?
I'm not acting like it's a joke. You have the product data, what more do you want?
And it's not called "Durarock". It just "Durock".
And no if it is no longer labeled as next gen I need to get new documentation to Cary in my trucks and submit for permits etc.
I'll help you out. Google "Durock product data sheet", click on the first link and hit "print". Done. Why are you being so obtuse?
I specifically told you in this case it is fine. I just mentioned that I need to get new copies of the msds sheets for the new product. Which yes is not new but it has a different name so the old sheets no longer apply.
And yes I spelled it wrong good for you.
Never mind you are hopeless.
No, because they don't have product for your old data sheets. And, as distributors, it's their job to have data sheets for all USG products they carry.
