Duraliner Oval Liner Insulation Question
Yocbran3
2
New York
I am planning to run the Duraliner oval liner through an approximately 8x12 clay liner for a Lopi Revere insert. I am set on the several sections of rigid pipe and the connector to the stove, and will use a 3 foot section of oval flex liner to connect to the rigid pipe.
My question is related to insulating the 3 foot section of flexible liner. I can only find kits that are for insulating 15 to 25 feet or more. Is there a product available for insulating just the 3 foot section of flexible liner as the rigid pipes are already insulated?
Thanks for any help you can provide.
Duraliner makes an insulating sleeve for the flex section. For 6" the part is 7102-ZC. It will need a band clamp top and bottom, part 4910
Thanks. With those part numbers I was able to find that they discontinued the sleeve as of 1/1/2023 and replaced it with a kit consisting of ½” x 5’ ProFoil insulation and a 5’ section of ProMesh. Now to see if I can find the kit.
Reactions: yuryk
Whoops, I see that my doc is dated 2008. Time to update this one.
Here is their prospect about that. I was looking for the same and found this thread, so learned something new :)
  • DuraLiner-insulationkit_2012_w.pdf
