- Can duraflame® firelogs be burned in all types of fireplaces?
Duraflame® firelogs are Underwriter Laboratories (UL) Classified for use in zero-clearance manufactured metal fireplaces and are suitable for use in all types of traditional open hearth fireplaces. Duraflame® firelogs should not be burned in wood stoves or wood stove fireplace inserts. Check for the UL-Classification mark on the package before buying. For more information about the wide range of fireplaces available today, visit the HearthNet web site. (wow, neat!)
- Can you add wood to a duraflame® firelog?
We don’t recommend adding wood to a duraflame® fire. When you add other materials to the firelog, it can change the characteristics of the burn. For example, duraflame® firelogs are designed to burn one at a time with a controlled burn rate that burns the external surface area of the log slowly exposing more internal fuel as the log burns. Adding wood to a burning firelog can cause the log to break apart result in a sudden increased burn rate or flare up. If a flare-up like this occurs, flames can consume your fireplace creating more heat and smoke than your chimney is designed to exhaust; resulting in unwanted smoke potentially pouring out the front of your fireplace. Firelogs also contain twice the BTU energy content per lb of firewood, so burning firelogs with wood could create excessive heat that exceed the specifications of your fireplace. Because of this and similar potential safety hazards, we recommend against adding other materials to a duraflame® firelog.
