I wish to put a wood stove in an existing two story house and have been looking at the options for a chimney. The outside versus inside chimney is something I have been trying to figure out. It is possible to put a metal chimney inside the house and go up through a second floor closet and out but I would perfer to go outside wih the chimney. I thought about a masonary chimey maybe with an stainless steel pipe and insulated or using dura vent triple wall pipe going outside. I guess the concern is outside versus inside chimney in term of draft. If I went outside with dura vent triple wall wouldn't that eliminate a lot of issues of a cold flue once I heated the flue up in the begining. Any ideas or how they might compare would be much appreciated.
Thank You
Thank You
