GotzTheHotz said:
Just wondering where you call it quits and say too much, if you're like me, that's when things go wrong (guy thing?). There are basics to felling a tree safely, no one wants to share? The tree I'm talkng is a 30' 16" maple, I think the top branches may just kiss the house. First cut straight 1/3 to 2/3's of diam, notch cut to meet, take the wedge out, back hinge cut 1-2" above first cut? No ropes. I know about chainsaws, I work in a rural hospital. Happy Friday all, be back in a minute as the Labatt is calling. No tree felling tonight, unless nature does it on her own.
All trees are "10". Period. Kind of like firearms .
Some armchair QBing from a distance for your happy-maple-to-kiss-the-house that you can think over:
1. Find the lean direction. All trees have a direction of lean and/or top weighting--they grow that way. You'll be surprised how it's easy to see the trunk lean. Walk around the base again. The crown branches will be larger usually towards the south, not always.
2.Learn how a strong hinge, cut correctly will allow the weight of the tree to hinge where you want it.
3. Wedges, even with a 16" DBH will lever the tree over so that the good hinge will carry the weight of the falling wood in the direction needed.
4. Undercut so that the trunk falls right: no "bounce back", no slide to one side, no "barber chair" slice up the trunk.
5. Back cut slow and carefully. Keep that hinge strong and straight across the complete width of the trunk. Stop. Look. Listen. Pound those wedges in (they are the real plastic ones, aren't they ?). Listen with your muffs off while pounding.
5. Want to use a rope ? OK, I give. Get a good one, get it high. Get plenty of tension with carabiners and a come-along. Secure it at a good angle to another tree ( don't have "your friend" or wife pull
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
All part of the thinking and planning even for a 16". Get out the camcorder.
Walk away if the tree looks too demanding. We do it all the time.
