So, I got this from my neighbor who always swears everything he has will work with minor tune-ups.
This thing sat outside with a crappy tarp over it for at least 5 years in the Santa Cruz mountains where it is VERY rainy for 4-5 months out of the year. The ram was about 1/3 extended, but it doesn't have any rust on it.
Instead of trying to make the old Briggs & Stratton motor work I just bought a predator that magically had all the exact same mounting holes. It's like it was made for this splitter.
I did NOT replace the hydraulic fluid, but I did top it off with about 2 gallons. It did not seem to have much excess water in it, but I am inexperienced. What's the best way to tell? It doesn't look particularly cloudy...
The pump seems a bit leaky and there's definitely a leak where the hose goes into the part that holds the filter (which I did not replace).
My issue is that I started the motor up, and got it running smooth and then went to go try to run the ram and there's no reverse on it. It extended just fine, but it won't move back and there doesn't seem to be any detent. Is this an issue with the control valve? Is it just that I don't have enough pressure?
I'm a total noob, but I'm a pretty quick learner. Let me know your thoughts!
I'm trying to post a video, but it's too large for this post. I'll try to link to it.
![Duerr 20 Ton Splitter won't retract Duerr 20 Ton Splitter won't retract](https://www.hearth.com/talk/data/attachments/248/248430-c9c91e9914a9a85945be47a987d533d1.jpg)
![Duerr 20 Ton Splitter won't retract Duerr 20 Ton Splitter won't retract](https://www.hearth.com/talk/data/attachments/248/248431-29efd118c94b2ac566f88af26a0d20b6.jpg)
![Duerr 20 Ton Splitter won't retract Duerr 20 Ton Splitter won't retract](https://www.hearth.com/talk/data/attachments/248/248432-3b11e5926d68737bd2d5c76354ae7ace.jpg)
![Duerr 20 Ton Splitter won't retract Duerr 20 Ton Splitter won't retract](https://www.hearth.com/talk/data/attachments/248/248433-fc6b516fcfac04d667e51d41d51f3320.jpg)
![Duerr 20 Ton Splitter won't retract Duerr 20 Ton Splitter won't retract](https://www.hearth.com/talk/data/attachments/248/248434-d63ba2962c5d13838aba75f835cfe6a6.jpg)
![Duerr 20 Ton Splitter won't retract Duerr 20 Ton Splitter won't retract](https://www.hearth.com/talk/data/attachments/248/248435-51087aef3512cfd6ee6899a86ced6e00.jpg)
