Sorry, but you're wrong. The dfference is fairly well known.Kong said:I don't think it has any less power when retracting than it does when extending. Its the same pump, same valve, same pressure against the same diameter piston; mine is no slower in reverse than it is when splitting either.
That adds up to 40 man hours for 15 cord or 2.66 man hours per cord. Considering the number of man hours to get the wood to where you can split it, and the man hours to deliver it to the customer, you're not getting rich quick.wellbuilt home said:We can split 15 cord in 8 hours if we are humping 3 splitting 2 stacking .
Not really, there is a difference, namely the diameter of the piston rod, which only sticks out on one side of the cylinder - This makes the volume of fluid that needs to be pumped per inch of piston travel less on the return stroke than on the extend stroke. Bottom line, the return stroke is slightly faster, but not as powerful as the extend stroke. The difference is not huge, unless you have very accurate timing, you probably wouldn't be able to see it by eye.Kong said:I don't think it has any less power when retracting than it does when extending. Its the same pump, same valve, same pressure against the same diameter piston; mine is no slower in reverse than it is when splitting either.
LLigetfa said:That adds up to 40 man hours for 15 cord or 2.66 man hours per cord. Considering the number of man hours to get the wood to where you can split it, and the man hours to deliver it to the customer, you're not getting rich quick.[/quotewellbuilt home said:We can split 15 cord in 8 hours if we are humping 3 splitting 2 stacking .
Ya I never talked to any one that got rich selling wood .
But its better then it sounds . MY stacker's are my daughters 5/7 years old . The wood crew is my 2 younger sons 12/14 Lucky for me little john is 6' 1" 220lbs @ 14years old .
I split the wood smaller then i would like because its still a little to wet to burn . I'm getting a lot of calls for wood and would like to have something to sell in a emergency . This stuff should be burnable in Feb if it stays cold and dry. I get payed to remove the wood off site and i can load and deliver a full load of wood 5 cord in about 2 hours . John
richfl said:Does anyone have or use one of these double-action log splitters like the NT Powerhorse or the Split Fire? I am thinking about getting one but am not convinced there is a real increase in productivity
Me thinks you missed the question. This thread is about splitters that split in both directions like a double-bit axe., pushing and pulling, not about 4-way wedges.Ducati996 said:I use it on the Norstar 37 ton below....its easily removable when doing verticals or if you dont want the splits too small.
