I have 2- 350’ loops of 1” Wirsbo Hepex off a 1 ¼x1x1” tee to supply 90,000btu min for the house and domestic h/w. Andrew at Wirsbo said that hepex 1”, 350’ loop, pumping 9gpm would produce a 10.55’ head. I am figuring a 12’ head including the fittings and HX.
Initially I was going to go to a Grundfos 15-58 but realized I would be running at the borderline of the curve on 3rd speed so I chose the Grundfos UPS 26-99 but after the recent discussions on flow and variable pumping conditions I am rethinking my order and plan to use 2- 15-58 Grundfos pumps, one on each 1” supply leg. I am thinking my head should stay the same but my flow would be cut in half. If I look at 4.5gpm @ 12’ it seems I am in the mid range of the pump speed. If I find out Slant Fin calculated high or low I am automatically covered by speeds 1&3;. in the summer when only the hot water is needed I should be able to run on one pump. The wto pump set up will be less costly also at $140 as compared to $239 and overall energy consumption will be lower. Another advantage is my other two pumps will be 15-58’s so only one spare would be needed if I chose to have one.
Before I order the pumps a question, is my thinking faulted?
Thanks, George
Thanks, George
