Hi All, Looks like I may be assisting in sanding a house worth of someone else's drywall and possibly some of my own. I have hired it out in the past but the folks who do it in my area are slim to none (no immigrant population to speak of and in general the local population is getting too old to sling drywall). So between the two of us we are looking to automate or at least do more sanding and less sweeping and splitting the cost. I see the Hyde units which are basically hand sanders with a vacuum cleaner hookup. Next step up are the electric drywall sanders on a pole hooked to a vacuum cleaner. Years ago when I did my last project, the drywallers I hired used a pole type electric rotary sander. It was impressive, took them about as long to haul the equipment up and down stairs and assemble as it did to sand with minimal cleanup, they just wiped down the walls and sprayed primer one with electric sprayer and they were done.
I used to see a lot of the Porter Cable 7800s around but they appear to have been rebranded to Dewalt 7800. Looks like $500 not including the vacuum cleaner. A few hundred more for the cordless (less if you are in the 20 volt Dewalt world). Lots of more expensive brands out there. Then there is the far less expensive WEN and a lot of chicom gear.
Note none of us are skilled tapers, no doubt we will be slapping more mud on than a pro. I think we will use the different premix formulations for the prime (low dust) and final skim coats but definitely it will be learning curve.
A drywall lift is on order, Last ceiling I did was a tray type ceiling using baker staging and 12 foot sheets. Not fun but did it solo with the baker staging and "T" stands.
So anyone have any sage advise?
