Drying Red Oak - cool photo
cycloxer
715
Worcester County, MA
So a lot of people have asked how you know when your wood is ready to burn. Well you can use moisture meters, you can weigh it, you can wait a year, etc. - there are many methods. So I have some oak that was split in November and I wanted to see how it is aging. So I took a split and split it again. You can see from the photo the amount that has dried out and the amount remaining to dry. Pretty cool.
  • [Hearth.com] Drying Red Oak - cool photo
wow good picture!!!
do you debark yours as well?
No, that piece just happened to come out that way. I burn all pieces of the tree, lol.
I just thought this was a good picture to visually explain to people how wood dries out. You can't always see the moisture in the wood, but this picture makes it pretty clear.
I would have expected it to dry deeper at the end grain. Is that solely a moisture difference or is there a temperature difference that caused condensation?
This wood has been stored outside in New England temps, covered. So the wood doesn't get wet from rain, but it is exposed to the outside air. It was all cut to length and split at the same time so maybe that is why. I have noticed this on a few pieces that I split so I finally took a photo. I brought the pieces inside and if I go to take a picture tomorrow you will see that the water marks are gone. The wood also has a pungent, oaky smell to it and it has that classic, dense oak feel.
It has very wide annular rings, always a sign of very dense wood in a ring-porous wood like oak. That also means it is very slow drying because these woods do most of their drying along the long tubes next to the early (dark rings) wood. That's why it hasn't dried so much at the ends.
Very interesting. Thanks for posting that. It's really good evidence that not all trees within the same species will produce superior wood. The BTU charts are only averages. Not all oak is equally dense. That wood grew fast and out in the open - the best place to find oak, ash and hickory, but not maple and cherry which grow denser under the forest canopy.
Well I was going to post an updated photo to show that the water marks are gone after 1 day inside, BUT somebody in the house decided to put the splits in the stove since I left them on top of the wood pile by the stove. LOL. Sometimes you can't win.
Pantalones - What size splits do you make? How long do you dry them out? How does it burn?
I'm the first to admit I'm not very smart. So, assuming the darker color is wetter, why is the bottom edge of these pieces not drying like the upper edges? It's the thinnest parts of the wood? What am I missing here? And be gentle.
You better clean the chimney in the morning so you don't get a fire from the creosote!
I think a couple of wet splits in my 650 degree incinerator will be okay. I run the secondaries like a blow torch.
