Hello everyone, new here, and trying to figure out some issues with a stove I installed last season.
Little background, I heat solely with wood, about a 12-1300sf house. The house came with a old small Cemi woodstove, and I used that for the past 4 yrs. It worked well, but has a small 16" firebox, and did not have long burntimes.
Last winter, I found a nice used NG1800 stove, (from what I can find online, it's an early Drolet Austral?), and installed it in the house, and installed the Cemi in the garage for heat out there. (Perfect garage stove).
Overall, I really like the Drolet. Nice big firebox that can fit 20" logs, lasts all night or all day on a load, a window to see the fire..
However, it seems to have an airflow or draft issue that I can't figure out. Fires take a while to get started, and I have to have the door cracked for 20-30min or else it will smolder down even with airflow all the way open. (house will sometimes fill w/smoke)
The 2nd issue is reloading. I'll crack the door for a minute, airflow all the way open, have the door open for maybe 10sec to throw some logs in, and the room is now full of smoke.
The stove will typically not get above 400* unless the door is cracked, even with airflow all the way open.
Any ideas on what the issue could be? It's the same chimney and pipe setup that I used with the old stove, minus one 45* bend. I clean it annually. I use the same wood in both stoves. I only see one airflow control on this new stove. It has 2 baffles up top, that don't look clogged..
The old stove you can hear it sucking in air when it's really going, never had issues with smoke flowing back into the room.
The new stove just feels like it's choking itself sometimes.
Thanks in advance for any advice, I attached some pictures and can get more if needed.
