My secondary air inlet seems to have rusted out. Anyone have this problem and have any advice what todo to fix it?
This is a drolet heatpack.Which model do you have ?
I will be following this because I bought an Escape 1800 last year.
I doubt it over fired. I have damper, and also the temp monitor for fire ups. I've never seen my flue temp over 600. I have it close down at 450 and open at 350... I keep my draft set to .2 basically most of the time also. I've seen my temp gauge on the front go above 500 about 3 times since if had it.It's certainly repairable by a welder though if it's outside of warranty.
.2” even seems very high. Is there a spec referenced in the manual?I doubt it over fired. I have damper, and also the temp monitor for fire ups. I've never seen my flue temp over 600. I have it close down at 450 and open at 350... I keep my draft set to .2 basically most of the time also. I've seen my temp gauge on the front go above 500 about 3 times since if had it.
Is it a coincidence that the rust out hole kinda lines up with the cracked firebrick?My secondary air inlet seems to have rusted out. Anyone have this problem and have any advice what todo to fix it?
YesIs it a coincidence that the rust out hole kinda lines up with the cracked firebrick?
