I've learned a lot by reading the other install threads on here, so I thought I'd start my own. This is my first time installing an insert or stove, so advice/criticism would be appreciated. I'll be installing the insert and liner in an existing masonry fireplace/chimney, in a circa 1975 ranch home.
Drolet Escape 1800 insert and liner:
Here's the existing fireplace:
Since I got a good deal on the insert from Costco and will save a bunch of $ by doing the install myself, my wife and I decided to splurge and have a stone veneer and wood mantel installed on the fireplace. I have zero masonry experience and already have a big backlog of house projects, so we decided to hire a pro for this. He came over on Friday to do the prep work, starting with grinding off the existing mantel and decorative arch, and knocking the top row of brick off the hearth. The existing brick work is painted, which the veneer mortar won't adhere to. Solution was to affix a wire mesh and cover that with mortar. The mason will be back in about 3 weeks to finish the work, after our stone order comes in.
Started working on the install today...here's the existing damper. It's only about 4" wide, so it's gotta came out.
The angle grinder made pretty short work of it...came out much easier than I thought:
I may have gotten a little overzealous with smoke shelf brick removal, but I figured it's better to have too much clearance than too little.
View up the chimney...the interior dimensions of the flue are 11" x 11", so running the liner down should be easy (knock on wood). There was no rain cap on the chimney and it rained a bunch yesterday...pretty wet in there.
View of of chimney from up on the roof. Took some measurements to make sure it met the 3-2-10 requirement.
Measured exactly 12' from the top of the flue tile to the bottom of the hearth. The minimum chimney height (from the top of the insert to the top of the chimney) for the Drolet insert is 12', so so I need about 1.7' more height. I ordered an 18" flue extension from Rockford, and factoring in the few inches of height I'll get from the top plate and rain cap, I'll be at exactly 12' of chimney height from the top of the insert. Hopefully this will be adequate.
I'm pretty much of a stopping point for the time being; waiting for the insulation kit I ordered from Rockford to show up. Will probably work on fabricating the damper block off plate this week.
