I haven't had any issues with warpage. Same mfr different name, Osburn 7000. The door glass gets dirty quickly is the only troubling issue so far. Although I've had it up to the max output, I didn't have it there long. If I need more heat just cranking it up half way gets it done.Whats with the warping over the door on these stoves? Are the newer models doing it as well?
Do you have yours ducted ambient? That osburn looks really nice.
No ducts, just ambient air heating the house. Sorting out available pellets and the combustion settings. Two different pellets can be adjusted to be burned for a bag a day. Others not so well.
I have a friend in town that has had a world of troubles with his pellet boiler. He is seriously considering swapping it out for a furnace type set up. I told him about the ability to duct this stove.
Oh no kidding? I didnt know you could fine tune these stoves. Ive read hyfire make mention of doing such things but sounds like its kinda a secret. Id love to be able to tweak and diag via laptop. Im sure its coming tho! Im a diesel tech by trade and 90% of my time is spent with a laptop.
OSBURN 7000:
6.1.6.2 COMBUSTION ADJUSTMENT (Fuel Quality Adjustment)
The “COMBUSTION ADJUSTMENT” will allow you to modify default settings by ±5% for auger motor 1 and ±10% for combustion and exhaust fan.
5.1.3 Convection Fan Speed Control
The convection fan can be adjusted to 9 predetermined speeds. By pressing on AUX, the message FAN followed by a number between 1 to 9 will appear on the screen. It will be possible to modify the blower speed by pressing on the + or the -. Take note that not all fan ranges are available, but the speed of the convection blower is consistent with the requested burn rate.
5.1.4 Heat Level
By pressing + or -, you can set the pellet feed rate and hence the heat output of your stove. The levels of heat output will incrementally change and each LED indicates the level from 1 to 6.
5.1.5 Reset
The reset button has to be used to clear most warnings on the control panel and restart your stove (see Section 6.6: Operating the Stove Using a Thermostat and Section 8.3: Main Error Codes, Possible Causes and Solutions).
I've have a digital tablet to make my adjustments. The Osburn 7000 allows adjustments to the Auger and the Combustion and Exhaust fans
So the osburn is more adjustable and you can use your tablet? Thats awesome! I actually found a dealer near me who sells both stoves. Im excited to look at both this weekend.
Yours looks like this:
DROLET ECO 65:
By making adjustments to these on the minimum setting, I can make the adjustment for the quality, or lack of in each type of pellet. I then take my paint pen and mark on the underside of the lid what each setting is. So if I need to switch to a previously used pellet I should be close to what it take to make it happy.
I called it a tablet, their official term for it is:
OSBURN 7000 TOUCH SCREEN BOARD (LCD) WITH HOUSING @ $325 replacement
Usually, the body will warp wherever there is flame impingement for a length of time in maximium run conditions. The easiest fix is of course fashioning an impingement plate as a 'sacrificial lamb' to deflect the flame and keep it from contacting the body of the stove, and/or you can add an internal gusset to strengthen the impacted area, which, is what I did with my USSC 39-41 after I noodled the body above the door which is the hottest part of the unit.
Took a bit of blue point tool work and body hammers to straighten and then an application od a 1/2 x 1/2" angle to the inside of the front wall above the door arch, not an easy weld because of the confined space but doable with mirrors and patience. I'd not recommend the latter unless you were a skilled welder and had pulsed MIG available.
In most instances a correctly placed impingement plate (which will become a consumable item) will work just fine.
Just keep in mind that any impingement plate will become a wear item as the metal erodes away from the oxidizing flame. Don't matter what it's made of though 3 sieres stainless will last longer than say low carbon mild steel, the price difference for the stainless versus the lo-carb isn't worth it. You can use anything, it just needs to be thick enough to resist warping, I'd recommend 0,125" or better.
OK for some reason I woke up this morning and was asking myself " Why did those stoves warp? What are the circumstances that led to the warping of your stoves? Could they be reproduced unintentionally on my stove?
Are they older stoves with thinner and less resilient steel?
SO before I got a handle on the minimum combustion settings I had this puppy cranking one day. The metal on the face of the stove above the door got over 850 degrees. I figured that was enough and shut it down. So we are talking temps well above that and a burn time in excess of 10 minutes...note to self: burning at 70K btu's may damage the stove.I would not say thinner steel, just maybe less supporting around the door. Extended burning on high feed rate I would say is the cause, over firing.
