Hello all:
Been planning my wood stove install (Drolet Escape 1800) for a while now by lurking, was looking for a couple of opinions on a design question.
My wood stove will be installed in the low corner (closer to the gutter) of a cathedral ceiling room, with a clerestory style roof .
I will be using DVL double wall stove pipe, the Duravent Cathedral ceiling install kit, then the applicable amount of of exterior chimney pipe.
I can either:
A) run straight up through the celling above the stove, through the ceiling/roof and up into the chimney. This will probably be simpler, but will result in about 8-10 feet of exterior chimney compare to about 7' of interior stove pipe. Aesthetically it will look better inside, but not so great outside.
B) Run up to the ceiling (with necessary clearances) 30 or 45 elbow to follow the ceiling line, then another elbow to penetrate the roof closer to the ridge, resulting in about 6' of exterior chimney run. This will probably look aesthetically worse inside, but will be cleaner outside.
My questions are:
From a performance standpoint, is it better to have more interior run, compared to exterior?
Will the elbows affect that performance?
A pretty thorough internet search has only revealed to me 45 and 90 double wall elbows by Duravent, am i missing something?
rough sketch attached for reference.
Thanks in advance.
![Drolet 1880 install - Interior or Exterior Pipe Run Drolet 1880 install - Interior or Exterior Pipe Run](https://www.hearth.com/talk/data/attachments/298/298798-3333202c3b6af49a6fe30450baeb9fc1.jpg)
I can either:
My questions are:
Thanks in advance.
