I burned all last winter for the first time in a new Oakwood stove, all hardwood. Granted, there was a learning curve and I started burning fires waaay to "cold", but by New Year's I pretty much figured it out...
I allowed the stove to jack up to 600 (stovetop thermo) probably every day, and occasionally it would crank to over 700 before I could close it back down, but these were only temporary, and my wife and I could usually get it to simmer between 400-550.
There WAS a time, however, when I ran out of wood in late Feb or early March, where we burned a fair amount of green oak which naturally didn't like to start, OR burn very hot...
So last weekend a wren came down my chimney and got trapped in the stove itself, and to get it out I removed the single-wall stovepipe from the stove collar to the double-wall ceiling/roof connector.
The stovepipe had a VERY thick, flaky layer of creosote, while the double-wall chimney pipe was VERY clean!
Does this sound typical? I would have guessed just the opposite, that the single-wall pipe inside the house would have been clean (closer to the fire, not in contact with outside cold temps), while the outside double-wall would have had the creosote buildup.
What should I do to minimize this inside-the-house creosote buildup, short of burning higher temps, and making sure I don't burn anymore green wood?
