Does anyone know what the draft settings should be for a pelpro home heater 120? I tried contacting pelpro and that was a waste of time as all they said was high should be higher than low. So what should the numbers be?
Edit: Welcome to the forum and good luck with set-up. We like pics....
Hope you remembered surge protector, smoke and CO detectors, fire extinguisher in the stove room away from the stove...
Used stove? Make sure you have cleaned all the internal exhaust pathways (easier to do outside with compressed aire but you might be beyond that from the sounds of it!)
