Installing through the roof at the peak. Any ideas as how to seal it right since the flashing wont work?
LLigetfa said:You cannot go through the roof with doublewall smoke pipe. The smoke pipe needs to end at the ceiling and connect to a class A chimney which is approved to go through the roof.
I'm hoping he's using the wrong termanology.LLigetfa said:You cannot go through the roof with doublewall smoke pipe. The smoke pipe needs to end at the ceiling and connect to a class A chimney which is approved to go through the roof.
Most modern construction no longer has a ridge pole at the ridge, so no alteration needed.Jasper 83 said:How do you put the chimney thru the peak without some restructuring of the roof? Seems like it would be easier and better for the house to move it down the roof a foot or two
tfdchief said:Most modern construction no longer has a ridge pole at the ridge, so no alteration needed.Jasper 83 said:How do you put the chimney thru the peak without some restructuring of the roof? Seems like it would be easier and better for the house to move it down the roof a foot or two
