Double Wall Insulated vs triple wall
JimP1
2
GA
I'm replacing my useless FP insert with a freestanding wood stove sitting a few feet from the wall where the FP used to be. I'm to the point finally that I need to run some pipe and all my research has clearly indicated that triple-wall class A pipe is the pipe for the attic all the way out. So I call the only dealer around and he says no one uses that anymore, they used 'double-wall insulated'. I'm told it meets the 2100 degree test. It's also $212 for a 4' piece. So is this true or should I deal with another vendor?
Double wall meets the code. You should shop around as this is available through dealers, big box stores and on-line through many that advertise on this site.
Triple wall requires the same 2" clearance to combustibles that is required for double wall class A. The difference is that it is 2" bigger in diameter, so you need a bigger hole.
There is no advantage over double wall.
I see, so triple wall is 2" larger. My stove will use 8" pipe, wouldn't it still be 8" on the other side of the ceiling in the attic where the Class A pipe connects? Or do I understand correctly that what was an 8" triple wall is now a 6" double wall that is designed to fit to a specific adapter in the attic?
You'll still see triple-wall DuraPlus class A pipe sold at some big box stores. It's a value line of pipe and is still class A. It is bulkier to install and requires a bigger hole in the roof, but it will do the job. My personal preference is for the double-wall insulated DuraTech pipe in that brand.
I think you are not understanding. Triple wall is larger OUTSIDE. They will all be the same inside in accordance with the specifications of the mfg of your stove. I have 8" inside pipe because I have a huge stove. Most stove pipe is 6". Only the inside measurements are quoted, just as water pipe, etc.
