- Feb 16, 2007
- 32
I am running black pipe from a wood stove into a masonry chimney. I have about 6-8 inches of clearance from the foundation beam where it goes into the chimney. Will I have to use black double walled in this area ?????
babalu87 said:Use double wall, over time the wood changes chemically when heated and cooled then its flash point becomes much lower.
Technical terms to follow , just not from me![]()
Upnorth765 said:Thank You for your kind replies.
Ok Double wall pipe it is. Now I have some another questions.
The 6 inch hole that goes from the house side into the clay liner of the chimney is about 4 inches thick from the inside in the house to the inside of the chimney liner. So.
1.Do I need to get the pipe all the way into the liner or jsut part way into it???
2. I ask because the opening is 6 inches but very very tight and I can basically only get the crimped end of a piece of single wall into it and then I would have to pound that in farther if I were going to get it all the way into the liner. Problem is that I dont think the crimped end is supposed to go in there... is it??? My manual says the crimpled ends are to go closest to the stove or doesn't it matter???
3. Can standard black double walled pipe be cut to shorter lengths as I need about 18 inches???
4 If I use an adjustable double wall piece can I break it if I pound on it to get it into the opening??
Upnorth765 said:quote
Describe the hole a bit - what is the chimney made of? What is the hole like, is it lined with a metal sleeve?
Thanks for the reply.
Ok.. is Thimble the technical term for the 6 inch hole going into the chimney from the house?
It is bacically concrete hole, no metal sleeve,its 6 inches and it goes into the chimney which is a cement block type chimney with a clay liner. It had a fuel oil furnace in it previously.
1. Maybe I could pound a piece of single wall 6 inch the hole and then leave a couple inches sticking out to mount the double wall piece to ???
Upnorth765 said:Quote ...A thimble is required code wise.
Thanks for the replies. I want this safe.
1. So then what exactly constitutes a thimble? If i take a piece of black singe wall and put it in the hole flush with the liner and leave an 1.5 of the crimped end sticking into the house. Is this a considered a thimble?
2. Then attach 12 inches of double walled pipe on that would that meet code??? It would meet my insurance inspectors code probably wouldn't it?
3. Do I need the masonary adapter as well with this set up or not?
4. Are you saying If I put double wall for 12 inches at the chimney I have to continue woth double walled all the way to the stove too??
Thanks guys
